Phish 1993 Project bumps @ LL - help needed
Discuss and post your projects (art, bands, sites...)
Postby jmitchell » Tue Oct 23, 2012 12:01 am
Any help out here would be appreciated. I am still a couple months away from starting the 1993 project. I am pretty sure some of the sources originally seeded here were from folks that frequent the forums here. All the sources listed are at 99.9%. There are quite a few. If you have the time to check and see if you can top me off I would be very grateful.
My post from LL:
We are still a few months away from starting the 1993 project. The majority of the sources have been seeded here before and I am gonna need a little bit of help to get some of them topped off. If you could please check your seeders wanted tab and see if you have any of the sources I am looking for, I would really appreciate it.
ph1993-02-25.CrownPZM.78840.shnf
http://www.shnflac.net/details.php?id=cccb7a5bf534769072289e4b074333d7d6174cb6
ph1993-03-25.schoeps.2349.shnf
http://www.shnflac.net/details.php?id=e22674fd2f943448183ff57edf2ee4b6f1af8056
ph1993-03-30.nak.515.shnf
http://www.shnflac.net/details.php?id=fbfb4ffbb24fbf6588912af75607ef57916bf641
ph1993-03-31.toak1.2055.shnf
http://www.shnflac.net/details.php?id=1f40ef432f10cba744d8233c6d3955bf8dc420a1
ph1993-04-09
http://www.shnflac.net/details.php?id=a0d1b4741ab906225d33e131bf4894cda11c1c68
ph1993-04-24.sony.521.shnf
http://www.shnflac.net/details.php?id=0f0e13e06a693d1bc1c02e9d15d3c958daa51b63
ph1993-04-30.shnf
http://www.shnflac.net/details.php?id=6f05a18b96ef4d402d9f6f2a5bfa9ce7647bda0a
ph1993-05-03.3598.shnf
http://www.shnflac.net/details.php?id=63c3cfa269b84f5a12c0629841db1adfb8974142
ph1993-07-16.5941.shnf
http://www.shnflac.net/details.php?id=6a48eec40345fdbcb14e3173deba78a47acf361f
ph1993-08-13.set2.sbd.1462.shnf
http://www.shnflac.net/details.php?id=70d0033e857ded58310ca3187d345ed6754d9688
jmitchell
Blog: View Blog (0)
Re: Phish 1993 Project bumps @ LL - help needed
Postby willbreathes » Wed Oct 24, 2012 1:44 pm
I'll do my best. Been a little while since I plugged in my drive.
User avatar
willbreathes
Third Eye Warrior
Blog: View Blog (0)
Postby jmitchell » Fri Oct 26, 2012 10:30 pm
I appreciate it Will. A lot of these sources were seeded 5+ years ago, so a lot of the original seeders aren't around anymore. I have a post here and at the paug, so hopefully between you and voopa (who I talk with on the hub) I can get these complete and don't have to create new ones. I have also started working on a spreadsheet for lossless Phish you may wanna check out.
https://docs.google.com/spreadsheet/pub?key=0AmqsXw4NEz0PdFJXVXgxelBzUFNVc3RnVUFkc0dldlE&output=html
Basically links the sources back to etree, LL and the setlist at phish.net. Source info, shnids and mp3 samples of each source are included, and when available I have included the same songs for a side by side comparison.
jmitchell
Blog: View Blog (0)
Postby willbreathes » Fri Nov 09, 2012 2:54 pm
Been staying away from my HDD unfortunately this past week. Sorry if I am letting ya down.
User avatar
willbreathes
Third Eye Warrior
Blog: View Blog (0)
Return to Member Projects
Who is online
Users browsing this forum: No registered users and 1 guest
cron
