Click the little wrench button and go to your preferences or settings and click the "basics" tab and then "manage search engines".
Under "Other search engines" type OhKeePa in the "add new search engine" box, type oks in the "keyword" box and then paste the address below into the URL box:
- Code: Select all
http://user9510.vs.easily.co.uk/ohkeepa/search.php?keywords=%s&terms=all&author=&sc=1&sf=all&sr=posts&sk=t&sd=d&st=0&ch=300&t=0&submit=Search
From then on you can just type oks in your addres bar, press space bar and type whatever word you wanna search the pa for and it will give you the results.
Or, you could just use that little white box at the top of the pa.
